Autor Subiect: Schimbare fahrenheit in celsius  (Citit de 1910 ori)
Offline AstSebastian
  • Mesaje postate: 8
    • Iasi
« : 06.Dec.2018, 09:27:49 a.m. »
Salut, ma poate ajuta cineva cu  schimbarea gradelor din fahrenheit in celsius la un SX4 2012? Nu stiu daca are importanta dar e modelul cu navigatie. Multumesc
Re: Schimbare fahrenheit in celsius
« Răspuns #1 : 06.Dec.2018, 10:42:22 a.m. »
Ce motorizare? E cumva benzina 2.0?
  • Mesaje postate: 8
    • Iasi
« Răspuns #2 : 06.Dec.2018, 11:47:13 a.m. »
Nu, e 2.0 Diesel
« Răspuns #3 : 06.Dec.2018, 01:38:59 p.m. »
Poti incerca in reprezentanta - poate exista vreo posibilitate de configurare electronica...
  • Mesaje postate: 8
    • Iasi
« Răspuns #4 : 06.Dec.2018, 07:25:55 p.m. »
Mi se pare stupid totusi...trebuie sa existe o varianta sa faci treaba asta din butoanele masinii
Offline aavii
« Răspuns #5 : 06.Dec.2018, 07:32:03 p.m. »
Si zici ca nu ai aceasta optiune in computerul de bord al masinii?
  • Suzuki Vitara S grade
Offline yeti
  • Mesaje postate: 1520
  • Thanked: 551 times
    • Bucuresti, Sector 3
« Răspuns #6 : 06.Dec.2018, 07:39:02 p.m. »
La o cautare cu Google am gasit asta:
You can change the unit indication of the thermometer between °F and °C.
To change the indication, follow the instructions below.
1) Hold in the “SET” button (8) for more than 2 seconds.
The unit display of the thermometer will blink.
2) Push the “SET” button (8) quickly to
2) Push the “SET” button (8) quickly to change the indication between °F and °C as shown in the illustration.
3) Hold in the “SET” button (8) for more than 2 seconds, and the unit indication will stop blinking.
If you don’t push the “SET” button (8) within about 8 seconds after the unit display starts blinking, the unit display will automatically stop blinking.
Fuel Consumption and Driving Range (3)
Vitara
Mokka
  • Mesaje postate: 8
    • Iasi
« Răspuns #7 : 07.Dec.2018, 08:47:15 a.m. »
@yeti: Am gasit si eu treaba asta pe net doar ca arata un altfel de bord...cred ca era de swift daca nu ma insel.
  • Mesaje postate: 8
    • Iasi
« Răspuns #8 : 07.Dec.2018, 08:48:02 a.m. »
Daca o fi , eu nu am gasit :)
Offline Leutz
« Răspuns #9 : 07.Dec.2018, 08:58:50 a.m. »
Optiunile de tipul asta nu sunt in computerul de bord. Se gasesc pe internet instructiuni insa.
Ele de obicei includ fel de fel de combinatii de "miscari", unde "miscari" include butoane din bord, butoane de prin masina, contacte usi ... etc. Cam orice care poate produce un semnal electric identificabil de calculatorul masinii.
De exemplu, eu la SX4 am consumul afisat nativ in Km/litru. La un moment dat am gasit pe net o chestie si l-am schimbat in litri/100km. Dar la deconectarea bateriei revine tot timpul la starea native, asa ca am renuntat. Oricum, conbinatia nu e una pe care sa o tii minte; si mi-a fost lene sa caut din nou pe net.
Sunt curios totusi de ce la tine e in Fahrenheit  :dknw:. Prin ce parte a lumii esti? La mine afisarea in Km/litru e cea standard din Jp. S-ar explica prin faptu lca masina e facuta in JP, cu volan pe dreapta, pentru piata din Australia. Deci nu s-au mai obosit sa schimbe starea default. Sau au uitat  :-)).
L.E. Acum vad ca scrie Iasi la profil ...  :D, deci masina e clar facuta pentru Europa (si in Europa).  O fi ceva zona crepusculara pe-acolo. Sau ... daca nu ai masina de noua, o fi schimbat fostul proprietar setarile. In cazul asta decupleaza bateria si-si va reveni la setarile default.
