Autor Subiect: Update 1860 HU SLDA  (Citit de 55973 ori)
Offline telegrafistu
Re: Update 1860.1
« Răspuns #10 : 29.Aug.2018, 02:34:37 p.m. »
L-am instalat de pe un SD card de 8G. Instalarea a mers snur. La final se restarteaza, apoi se opreste si trebuie repornit din butonul de pornire. Testat cu AA, Waze si Maps timp de max 10 min. prin oras. Nu a generat erori. Filmele pe care le aveam in versiunea anterioara le reda fara probleme. Nu am idee daca accepta si formate noi. Se pare ca are  unele probleme cu comenzile vocale. Cam atat deocamdata. Se pare ca versiune aceasta doar a remediat niste bug-uri, si anume:
Fixed:
a) CarPlay may not start automatically when the system is turned on.
b) When playing high-definition video, the screen may "hang" when the button is pressed further.
c) Audio can not be played when the head unit is turned on / off with a connected USB card.
d) You can not play music after the last track in the music folder, if the repeat function is off.
e) Improved operation of the touch screen.
f) Rebooting the SLDA device with an incoming call if voice control is used.
g) Hanging the SLDA device when connecting to a mobile phone via Bluetooth and then selecting Bluetooth audio with the MODE button on the steering wheel.
h) When moving at night, the screen can become bright for a moment.
  • SUZUKI VITARA 2015
The following users thanked this post: Catalln, emil_greus, Meltdown, razordan88
Offline musicall
  • Mesaje postate: 488
  • Thanked: 81 times
Re: Update 1860.1
« Răspuns #11 : 29.Aug.2018, 05:58:01 p.m. »
Au băgat limba română? Ce erori ai avut cu comenzile vocale?
Re: Update 1860.1
« Răspuns #12 : 29.Aug.2018, 07:17:13 p.m. »
Lb Romana nu exista, iar la comenzile vocale atunci cand nu recunoaste corect pe cine sa apeleze (caz frecvent) la comanda DIAL iti afiseaza o lista cu posibilii apelanti din care il vrea doar pe primul. Altceva nu am mai testat. Maine poate il vad la drum mai lung insa acolo nu ai timp de butonit.
Offline 3lzOR4B
Re: SLDA_SOP6.2a_(ver.1060.2)_EU
« Răspuns #13 : 30.Aug.2018, 08:28:39 p.m. »
https://drive.google.com/file/d/1O4EoFM_GgM66-Kr8hc_MeXyawVY0cKyS/view?usp=sharing
Un link pentru ultimul SLDA_SOP6.2a_(ver.1060.2)_EU pe care tocmai l-am instalat...Fara probleme, nu reboot pe la 97%, etc...A mers dintr-una!
Si e pe Google Drive so...Profitati de speed la download
  • Vitara 2017
Offline berila_mz
Re: Update 1860.1
« Răspuns #14 : 30.Aug.2018, 10:18:46 p.m. »
Link-ul nu mai e valabil. Rog sa il repuneti cei care au reusit sa faca update-ul si doresc sa impartaseasca...
Trimis de pe al meu MHA-L29 folosind Tapatalk
  • Suzuki Vitara 1.6 AllGrip Spirit
Offline kellogs
Offline Emilian Sohterus
Re: Update 1860.1
« Răspuns #16 : 31.Aug.2018, 04:37:34 p.m. »
   Bună ziua! Nu am mai urmarit de mult acest subiect, așa că sunt puțin pe dinafară. îmi puteți spune dacă acest nou update (1860.1) vede MirrorLink. Aș vrea să-mi cumpăr: "Sygic Car Navigation"! Mulțumesc anticipat!
  • Suzuki Vitara S 1,4 Boosterjet AT allgrip
Offline ariciul
Re: Update 1860.1
« Răspuns #17 : 31.Aug.2018, 06:17:04 p.m. »
Cel mai probabil ca da, nu exista un motiv sa fi renuntat la el. Eu mai folosesc din cand in cand Sygic Car Navigation pe care l-am cumparat cu ceva timp inainte de a apare Android Auto. Eu cred ca am 1840 pentru ca nu am avut motivatie sa trec la 1850, cel mai probabil o sa-l fac si eu zilele astea. Trebuie insa sa-i specifici la setari (dupa ce accesezi panoul de conectare din dreapta jos) care aplicatie are prioritate la conectare, Mirrorlink sau Android Auto. Daca vei folosi Sygic vei pune evident Mirrorlink.
Re: Update 1860.1
« Răspuns #18 : 31.Aug.2018, 07:25:51 p.m. »
  Mulțumesc pentru informație! Acum sunt in Bulgaria, când mă întorc acasă voi încerca sa îl instalez. "Sygic Car Navigation" îmi dă 7 zile trial, așa că am timp să verific.
Offline ariciul
Re: Update 1860.1
« Răspuns #19 : 31.Aug.2018, 08:05:15 p.m. »
Poti sa-l instalezi si acum in Bulgaria si sa-l incerci, trebuie sa mearga deorece unitatea multimedia a avut posibilitatea de conectare pe mirrorlink de la bun inceput. Singurul lucru pe care trebuie sa-l faci e sa ai grija sa pui mirrorlink-ul cu prioritate la conectare si sa ai un cablu usb de date, preferabil cel original al telefonului.
The following users thanked this post: sx4fan
