Autor Subiect: Uleiul de motor  (Citit de 135666 ori)
Re: Uleiul de motor
« Răspuns #70 : 09.Iul.2009, 03:36:19 p.m. »
Din pacate obs ca 5w30-ul are calificative mai slabe decat 5w40-ul lor.
Am vazut ieri in Kaufland ulei BP 5W30 fabricat in Belgia.
Offline danker
Re: Uleiul de motor
« Răspuns #71 : 10.Iul.2009, 08:41:25 a.m. »
- Si inca un model.
Offline dragon
Re: Uleiul de motor
« Răspuns #72 : 29.Iul.2009, 09:10:43 a.m. »
Noi gasim uleiuri de care vrem,dar ni le pun ei?Ramine sa ne orientam si sa ne planificam excursii la serviceurile care agreeaza schimb de ulei cu ceea ce am cumparat noi! :dknw:
  • Suzuki SX4 1.9 DDIS
Memento mori!
Re: Uleiul de motor
« Răspuns #73 : 30.Iul.2009, 10:21:29 p.m. »
Pai sunt obligati sa te primeasca daca ai un ulei adecvat.
Offline Iahim
  • Mesaje postate: 345
  • Suzeta Splash 1,2
Re: Uleiul de motor
« Răspuns #74 : 10.Sep.2009, 12:44:11 p.m. »
Sper sa va fie de folos, in special celor care au fost aseara la Polivalenta:
300 V High RPM
Motul 0W-20
Racing Automotive Lubricant
Issued from Motul's Racing experience
100% Synthetic – Double Ester Technology TYPE
RECOMMENDATIONS
Oil change: according to manufacturers' requirements and according to your own use.
Can be mixed with synthetic or mineral lubricants.
PROPERTIES
Viscosity grade SAE J 300 0W-20
Density at 15°C (59°F) ASTM D1298 0.857
Viscosity at 100°C (212°F) ASTM D445 8.0 mm²/s
Viscosity at 40°C (104°F) ASTM D445 40.1 mm²/s
Viscosity index ASTM D2270 177
Pour point ASTM D97 -39°C / -38°F
Flash point ASTM D92 220°C / 428°F
TBN ASTM D 2896 11.3 mg KOH/g
MOTUl 5W30
Fuel Economy Engine Oil especially designed for recent engines, powered by turbo Diesel direct injection or gasoline engines, designed to use low friction and low HTHS (High Temperature High Shear) viscosity oil Suitable for new technology engines powered with turbo Diesel or gasoline engines and catalytic converters, requiring fuel economy lubricants (ACEA A1/B1 or A5/B5 standards).
These oils may be unsuitable for use in some engines. Refer to the owner manual or handbook if in doubt.
PERFORMANCES
STANDARDS ACEA A5 / B5
APPROVALS API SL / CF
RECOMENDATIONS
Drain interval : according to manufacturers’ recommendations and tune to your own use.
MOTUL 8100 Eco-nergy 5W-30 can be mixed with synthetic or mineral oils.
PROPERTIES
Viscosity grade SAE J 300 5W-30
Density at 15°C (59°F) ASTM D1298 0,852
Viscosity at 100°C (212°F) ASTM D445 9,9 mm²/s
Viscosity at 40°C (104°F) ASTM D445 57.7 mm²/s
Viscosity index ASTM D2270 159
Pour point ASTM D97 -36°C / -33°F
Flash point ASTM D92 226°C / 439°F
TBN ASTM D 2896 10,3 mg KOH/g
Offline danker
Re: Uleiul de motor
« Răspuns #75 : 17.Sep.2009, 12:46:12 a.m. »
-Vazut astazi in drum spre Grecia, (pretzul este in leva. ~2leva=1e,) fabricat in EU:
« Ultima Modificare: 17.Sep.2009, 01:03:26 a.m. de danker »
Offline lucianer
  • Mesaje postate: 8034
  • Thanked: 266 times
Re: Uleiul de motor
« Răspuns #76 : 17.Sep.2009, 09:29:43 a.m. »
Am vazut ca au aparut si la noi reclamele la uleiurile Shell.
In alta ordine de idei...tot despre uleiuri:
http://www.carbibles.com/engineoil_bible.html
« Ultima Modificare: 17.Sep.2009, 09:35:30 a.m. de lucianer »
Go Terios!!!:)
Offline sx4alex
  • Mesaje postate: 256
Re: Uleiul de motor
« Răspuns #77 : 17.Sep.2009, 10:15:50 a.m. »
Pe la noi se gaseste Shell Helix pe undeva?
SX4 4wd GLX Sunlightcooper primul din Targoviste :D
Offline lucianer
Re: Uleiul de motor
« Răspuns #78 : 17.Sep.2009, 11:47:23 a.m. »
Trebuie sa apara atata timp cat li se face reclama!
Go Terios!!!:)
Re: Uleiul de motor
« Răspuns #79 : 11.Nov.2009, 10:07:26 p.m. »
Are cineva niste explicatii in plus fata de ce se scrie aici: http://www.mobil1.com.ro/cms/Mobil_1_New_Life_0W-40.aspx ?
Este bun pt motoarele noastre pe benzina, nu este bun ? A folosit cineva un asemenea ulei ?
