Autor Subiect: New Vitara facelift  (Citit de 91089 ori)
Offline thematriksz
New Vitara facelift
« : 30.Aug.2017, 11:57:59 a.m. »
Desi articolul este in limba maghiara, cu un translate veti intelege. Au aparut primele poze neoficiale cu noul Vitara ce va fi lansat cel mai probabil in 2018.
http://totalcar.hu/magazin/hirek/2017/08/29/kemfoton_az_uj_suzuki_vitara/?utm_source=index.hu&utm_medium=doboz&utm_campaign=link
  • Suzuki Vitara 1.6 Passion 2WD 5MT / Savanna Ivory
The following users thanked this post: shpeedy, toma, wolfin
Re: New Vitara facelift
« Răspuns #1 : 30.Aug.2017, 12:02:23 p.m. »
deci va avea camera in loc de rbs...o noua bara si alte stopuri  :good:
greierasii sper ca i au eliminat
puteai sa ne traduci tu ce era mai important :) (glumesc)
aceiasi marie ...ca la duster apropo
Offline Mesmer
« Răspuns #2 : 30.Aug.2017, 12:03:16 p.m. »
Are si radar doar ca nu mai este pus in spatele siglei, ci mai jos, ca la S-Cross.
Sper sa reziste mai bine la zapada, eventual sa fie incalzit.
« Răspuns #3 : 30.Aug.2017, 12:46:20 p.m. »
"From a technical point of view, one significant change is expected: the 1.6-liter suction motor is expected to be replaced by the thousands of three-cylinder turbo engines . "
Cum se zvonise - M1xA-ul isi traieste ultimele zile pe Jimny si Vitara...
LE: astia de la AM (http://m.automarket.ro/stiri/informatii-despre-viitorul-suzuki-vitara-facelift-mai-multe-sisteme-de-siguranta-si-un-design-similar-79367.html) nu au descoperit inca Google Translate...
« Ultima Modificare: 30.Aug.2017, 01:08:35 p.m. de shpeedy »
Offline Lerua07
« Răspuns #4 : 30.Aug.2017, 12:52:15 p.m. »
Poate vor fi mai multe noutati interesante la interior si unitatea media  :-?
Offline dAlex
« Răspuns #5 : 30.Aug.2017, 01:25:06 p.m. »
Oare asta:
"and in a medium speed range - where it is typically used - it feels much stronger than the four-cylinder suction engine"
inseamna ca pe autostrada, la regim de viteza mare, nu trage la fel de bine ca asta in 4 cilindrii aspirat? Daca asa-i, cred ca urmatoarea masina n-o sa mai fie Suzuki Vitara pentru mine.
Adica, si asa il fortez pe asta in 4 cilindrii la 130 km/h si peste, sa iau unul mai slab clar nu-mi convine.
Si un minus la fiabilitate cred.
Din articol inteleg ca cauza principala sunt emisiile: "more secure emission standards". Deci platim mai mult ca sa fim mai eco.
Bine ca am apucat sa-l prind pe asta aspirat. Cine stie ce mai apare pana iau urmatoarea masina..
Offline jupanul1
« Răspuns #6 : 30.Aug.2017, 01:45:33 p.m. »
Deci motor nou turbo în trei cilindri. Ca pe SX4 S-Cross (sau cum i-o zice oficial), cel mai probabil (în articol zice că va avea cu 10hp mai puțin decât cel aspirat - 112hp vs 120 hp... s-ar cam potrivi). Dar asta înseamnă cuplu mai mare de la turații mai mici. Dacă pun o cutie (manuală) în 6 trepte, nu cred că va fi o combinație de refuzat. Chiar și cu 5, nu cred că-i rău, mai ales că-l laudă cu îmbunătățiri ”electronice”.
Per total, va fi perceput de consumator ca un ”upgrade” față de vechiul motor aspirat. Ca fapt divers, M16A nu s-ar mai fi calificat la programul rabla de anul viitor. De altfel nici K14C.
Ca observație personală - nu-mi place amplasarea radarului atât de jos. De gustibus...
« Răspuns #8 : 30.Aug.2017, 02:29:18 p.m. »
@jupanul1: motorul 1.0 turbo nu e chiar nou, el aflandu-se deja pus pe S-Cross facelift,  o masina olecutz mai grea fata de Vitara.  Avem si colegi pe forum cu aceasta versiune (chiar si cu Allgrip), dar n-am retinut ceva pareri pe marginea respectivei combinatii...
@f.cristi: ti-as recomanda mai multa atentie la deschiderea topicurilor noi (pentru a evita dublarea informatiilor),  dar frica mi-e ca ar fi in van...
« Răspuns #9 : 30.Aug.2017, 02:30:26 p.m. »
Offtopic:
[...]iar Salonul Auto de la Tokyo, din luna octombrie, este bifat de noua generație Jimny.
Sunt tare curios cum o sa arate, ce capabilitati off road o sa ofere si cat o sa coste. Poate se inmultesc japonezele din gradina mea ...  :-?
Ontopic:
Articolul spune ca motorizarile raman aceleasi.
Sub capotă Suzuki va oferi aceeași gamă de motorizări, compusă din două propulsoare pe benzină (1.6 aspirat și 1.4 turbo) și unul diesel (1.6 diesel).
