Autor Subiect: Cum se conduce Jimny pe asfalt?  (Citit de 20161 ori)
Offline lucianer
  • Mesaje postate: 8032
  • Thanked: 260 times
Re: Cum se conduce Jimny pe asfalt?
« Răspuns #20 : 01.Iun.2009, 12:38:23 a.m. »
Iti iese , linistit!
Go Terios!!!:)
Offline alexb25
  • Mesaje postate: 229
« Răspuns #21 : 02.Iun.2009, 03:37:10 p.m. »
Am gasit pe un site despre subiect, dar e in engleza:
"DRIVING TIPS FOR FUEL ECONOMY
•    Keep your tires inflated at correct pressure. Under – inflation causes tires to wear and wastes fuel.
•    Avoid lengthy warm up idling. In winter this may take a little longer. However once the engine is running smoothly, begin driving.
•   Accelerate slowly and smoothly. Avoid jack – rabbit starts and unnecessary sudden acceleration or braking. Get into high gear as soon as possible.
•   Avoid long and unnecessary engine idling. If you have a long wait and you are not into traffic, it is better to turn off the engine and start again later.
•   Avoid engine stress or over revving. Do not rest your foot on the accelerator pedal, for short period stoppages, for example at a signal.
•   Do not rest your foot on the clutch or brake pedal. This causes needless wear, over heating and poor fuel economy.
•   Maintain a moderate speed on highways. The faster you drive greater the fuel consumption. By reducing your speed you will cut down on fuel consumption.
•   Ensure proper wheel alignment. Avoid hitting the curb and slow down on rough roads. Improper alignment not only causes faster tire wear but also puts an extra load on the engine, which in turn wastes fuel.
•   Avoid unnecessary stopping and braking. Maintain a steady pace, keep a proper distance from other vehicles to avoid sudden braking. This will also reduce your brakes from wearing.
•   A/C usage increases fuel consumption, Operate the lever on re-circulate position to optimize cooling.
•   Always use Genuine Parts including A/C. Non- Genuine parts affect fuel-consumption, can be dangerous and can cause accidents.
•   Keep your vehicle tuned-up and in top shape, A dirty air cleaner, out of adjustment carburetor, dirty plugs dirty oil and grease, brakes unadjusted etc., all lower engine performance and increase fuel consumption.
jimnyholic
Offline >pexic<
« Răspuns #22 : 02.Iun.2009, 04:09:20 p.m. »
pt chestii generale ce se aplica tuturor masinilor avem chiar si un topic separat :
http://www.suzuki-club.ro/forum/diverse-9/10-sfaturi-pentru-reducerea-consumului-!/     :)
Offline luci_bigbos
  • Mesaje postate: 9
« Răspuns #23 : 03.Iun.2009, 01:29:41 a.m. »
sunteti tare de ajutor, deja ma simt ca in familie :)
multumesc si sper sa am ocazia de a va intoarce binele facut ;)
Offline lucianer
« Răspuns #24 : 03.Iun.2009, 10:26:19 a.m. »
Yap.Da-ne masina ta, sa facem un drive-test >:)
Go Terios!!!:)
Offline asterisc
  • Mesaje postate: 58
« Răspuns #25 : 08.Iul.2009, 08:48:58 p.m. »
Ca sa fiu on-topic:
Incearca sa schimbi vitezele usor sub turatia de cuplu maxim (pentru a evita si subturarea)
Off topic:
In curand vreau sa achizitionez un Jimny, tot din zona ardealului, Cluj Napoca.
Am cerut astazi un test-drive, sa vedem pozitia la volan, cat e de confortabil, etc, dar nu au jimny deloc pe stock.
@luci, ne-am putea intalni candva sa inspectez jimny-ul mai atent? (am ~1.92 inaltime, nu stiu daca incap in el, ce fel de reglaje sunt la scaune, la volan, ....)
Reality is for those who cannot face Science Fiction!
Offline lucianer
« Răspuns #26 : 08.Iul.2009, 08:56:03 p.m. »
Eu sunt acum in zona Siriu,Patarlagele(jud. Buzau), daca te ajuta cu ceva.
Go Terios!!!:)
Offline asterisc
« Răspuns #27 : 08.Iul.2009, 09:28:29 p.m. »
@lucianer: sunt bistritean la origine, + ramas in Cluj Napoca dupa facultate. Din nefericire esti destul de departe de zonele care le frecventez. Dar iti multumesc!
In postul precedent, ma refeream la @luci_bigbos, care am vazut ca este clujean.
Urmaresc in continuare cu interes orice subiect despre Jimny.
Offline lucianer
« Răspuns #28 : 08.Iul.2009, 10:55:19 p.m. »
 :D Sorry.
Te-as fi ajutat si eu, dar....esti departe.
Go Terios!!!:)
Offline >pexic<
« Răspuns #29 : 09.Iul.2009, 01:20:22 p.m. »
asterisc - poti da o fuga prin targurile de masini din zona ta, am vazut pe net ca sunt ceva jimny-uri de vanzare, ca sa testezi pozitia la volan etc...
