Autor Subiect: Multimedia si navigatie New Vitara  (Citit de 352341 ori)
« Răspuns #2430 : 20.Nov.2023, 09:35:40 a.m. »
pai s22 ar trebui sa aiba aa preinstalat.
nu gasesti apk in play? pt un update ceva...
si conectare prin cablul date original  B-)
https://support.google.com/androidauto/answer/6348029
Important: Android Auto Android Auto is integrated into phones with Android 10 and above. You do not need to download it.
  • Mesaje postate: 1610
  • Thanked: 252 times
« Răspuns #2431 : 20.Nov.2023, 11:21:57 a.m. »
@ariciul
Eu am un Samsung Galaxy A04s dar merge fara probleme si fara cablul original
Offline cornel40
    • Bucharest
« Răspuns #2432 : 20.Nov.2023, 04:00:24 p.m. »
Nu mai reusesc nicicum sa ma conectez pe AA cu un Samsung S22 desi ulterior am folosit un S7 si un Xiaomi 9t .Daca instalez un apk imi spune ca formatul nu e compatibil cu telefonul, ati mai intampinat careva situatia asta?
Pe internet apare acest model ca fiind cu probleme la capitolul AA.
Incearca https://www.techradar.com/how-to/android-auto-not-working-on-your-samsung-galaxy-s22-heres-how-to-fix-it si baga versiunea de acolo. Posibil daca ai deja AA instalat, sa trebuiasca sa il dezinstalezi  folosind metoda: https://www.makeuseof.com/uninstall-android-app-adb-system-apps-bloatware/ si sa instalezi versiunea specificata in acel articol.
Posteaza si ce versiune de Android ai pe tel + cea de AA
Mai poti incerca:
• Go to Settings >> About Phone >> Software Information >>  Build Number
• Tap build number 7 times to enable developer options
• Go back to previous screen once enabled and open "Developer Options".
• Swith on the developer mode and then scroll down to find "Default USB Configuration"
• Change the setting to "Transferring Files"
• Next comnect your phone to your computer or laptop and open your notifications.
• There, click on USB options and choose "Transferring files/ Android Auto"
• Restart your phone and then connect your phone normally to your car and android auto should trigger / boot up.
Sau un USB Hub pt Xiaomi.
  • Vitara 1.4 Mild Hybrid
Offline tac
« Răspuns #2433 : 21.Nov.2023, 04:15:46 p.m. »
Update-ul la andoid 13 a creat probleme pentru android auto la unele modele.
Offline kellogs
« Răspuns #2434 : 21.Nov.2023, 08:11:21 p.m. »
Uraaaaaa!
Offline ariciul
« Răspuns #2435 : 22.Nov.2023, 10:16:42 a.m. »
Si care-i rezolvarea? Android 14?
« Răspuns #2436 : 22.Nov.2023, 12:23:07 p.m. »
12
Offline ariciul
« Răspuns #2437 : 22.Nov.2023, 12:29:00 p.m. »
Nu multumesc, vad ca trebuie sa mai fac si backup pt ca implica si un factory reset, exact ceea ce voiam sa evit.
Altfel am rezolvat deja (am mai scris asta in topicul AA) cu un telefon mai ieftin tinut in masina numai pt AA (nu are cartela si ii dau net prin hotspot)
« Răspuns #2438 : 22.Nov.2023, 12:37:21 p.m. »
Eu am 13 pe s215g si  vad ca nu sugita. Foarte ciudat ca nubrezolva printr un update.
« Răspuns #2439 : 22.Nov.2023, 01:07:15 p.m. »
Am primit un update la AA ieri. Verifica sa nu fie vreo versiune mai noua decat ceea ce ai.
