Autor Subiect: Multimedia si navigatie New Vitara  (Citit de 345797 ori)
« Răspuns #2150 : 19.Mai.2020, 09:57:37 a.m. »
Daca nu te apuci tu sa-l faci, nu exista.
Pe langa partea hardware-ului aferent unui asemenea modul, pe parte de software ar trebui ca sistemul de operare al unitatii SLDA sa aiba si drivere pentru a accepta respectivul modul...
LE: uite topic de discutii pe marginea SLDA din perspectiva dezvoltatori:
Citat din: ..::Jacob::..;76248376
Wireless IMPOSSIBLE Bosch unit doesn't have the hardware for that.
Citat din: 7virage7;76255282
True, wireless AA will not work in our cars.
But to be honest, either way you will need to plug in an external charger to keep you phone running for longer travels. Therefore using USB connection for AA is not that bad - I assume it should be more reliable/responsive than wireless and ensures the phone is charged simultanously.
Citat din: m00n61;75808199
Android Auto can be automatically launched when connecting the phone.
Wireless connection to AA is not yet supported.
Before spending on one of these Chinese units, take a look at the dedicated Android Auto forums here:
https://forum.xda-developers.com/android-auto
As someone who has owned several such units I can tell you:
  • the Bosch unit has a far superior screen, much brighter than any Chinese unit
  • the current Bluetooth connection for phone calls is far superior to what you can get from any Chinese unit
  • current Chinese units have 1 or 2 GB RAM. That is not enough to run Android Auto on the HU
  • some Chinese HUs do have better FM radios
« Ultima Modificare: 19.Mai.2020, 10:22:35 a.m. de shpeedy »
Offline chriss
« Răspuns #2151 : 23.Mai.2020, 03:12:01 p.m. »
salutare
si-a montat cineva un navigator sau alt aparat pe suzuki Cool?
care este metoda de montare?
se poate sau nu? durata? pret?
am un aparat care as vrea sa il montez.
All grip
Offline Danke
« Răspuns #2152 : 18.Iun.2020, 09:26:20 a.m. »
Salut, a aparut navigatia SUZUKI SLDA 2020, testat si functioneaza bine. Cine doreste navigatia 2020 + CID, link download pe PM.
  • Suzuki Ignis 2018
The following users thanked this post: dacbuc
Offline chriss
« Răspuns #2153 : 18.Iun.2020, 09:51:32 a.m. »
Asta a aparut? :-)) :-)) :-))
Download link:
https://gofile.io/d/4h5hF9
Cid:
094150414620534499104e6707013200
All grip
The following users thanked this post: Catalln, kellogs, dacbuc
Offline Danke
« Răspuns #2154 : 18.Iun.2020, 10:37:19 a.m. »
Da. Nu stiam daca e voie cu link de download aici
  • Suzuki Ignis 2018
Offline ASZ
« Răspuns #2155 : 18.Iun.2020, 11:08:38 a.m. »
Intrebare: eu nu sunt sigur ca al meu card are CID reinsriptionabil (la cumparare, am fost asigurat ca este .. dar am rezerve) si nici nu stiu cum ar trebui facuta aceasta operatiune de improspatare a hartilor.
Ma poate ajuta cineva cu aceasta operatiune ? (si cu ceva info despre cum sa aflu daca e card cu CID reinscriptionabil)
Offline dragan
« Răspuns #2156 : 18.Iun.2020, 11:10:53 a.m. »
Eu am 2019-2020 de anul trecut. Sunt puse toate autostrazile care ar trebui inaugurate anul asta la noi. Era de vanzare pe ebay cu 36 de euro
Sent from my SM-N960F using Tapatalk
  • suzuki vitara 1.6 alltrack benzina 2017
Offline dragan
« Răspuns #2157 : 18.Iun.2020, 11:13:48 a.m. »
Asta ar fii cardul
Offline dragan
« Răspuns #2158 : 18.Iun.2020, 11:15:54 a.m. »
Cred ca urmatorul update ar fii 2021-2022
Offline dacbuc
« Răspuns #2159 : 18.Iun.2020, 11:19:34 a.m. »
Pai, incerci intai sa ii schimbi CID-ul cu cel nou; daca merge, stergi hartile vechi si le pui pe cele noi.
