Autor Subiect: Despre 4x4  (Citit de 94001 ori)
Offline Leutz
Re: Despre 4x4
« Răspuns #80 : 26.Mai.2009, 07:50:00 p.m. »
Revin si eu cu parerea proprie  :D SX4 does have ... cuplare uscata pentru puntea spate.
Pe forumul postat mai sus (http://www.sx4club.com/forums/showthread.php?t=3258), uitati-va si un pic mai jos de postarea despre cuplajul vascos. Dupa poatsrea initiala cu vascocuplul in cele 13 pagini de topic se ajunge la concluzia ca e ambreiaj uscat. Nu se mai gaseste nici o alta referire la vascocuplu. Iata o parte din concluzii. Citez:
1. "The viscous coupling is on the earlier full time AWD models not the SX4. You can see the electrical connection to the clutch on the nose of the rear diff"
2. "I also thought it was an electrically operated clutch and pressure plate, just like a manual transmission's. The article you linked mentions it's in the Aerio but the picture at the top is an SX4."
3. "The SX4's center differential is not a traditional one in the sense of having a dedicated ring & pinion with spider gears as in the front and rear differentials of the car, but rather it is a clutch pack coupler between the rear driveshaft and the rear differential."
Afirmatiile sunt sprijinite si de o clasificare data de wikipedia, in care SX4 e in categoria "Clutch Pack Coupling"
Evident, cea mai buna metoda de a afla adevarul e un telefon la oricare din service-urile Suzuki de oriunde din lume  :D
Offline bogdanb
Re: Despre 4x4
« Răspuns #81 : 26.Mai.2009, 09:00:13 p.m. »
Leutz, adica la orice service din lume in afara de Romania ! :D
SX4 4x4 1.6GS aka Suzie Q :)
Offline cristian_ionescu
  • Mesaje postate: 236
Re: Despre 4x4
« Răspuns #82 : 02.Iun.2009, 03:38:08 p.m. »
1. Pentru cei care nu stiu cum arata si cum functioneaza un cuplaj vascos am un articol "mioritic", scurt, pe intelesul tuturor: http://www.totteren.ro/Diferite%20tipuri%20de%20tractiune%20integrala.htm.
2. Cei care mai au dubii in privinta cuplajului de SX4, cautati in manualul de reparatii si veti gasi raspunsuri pentru toate intrebarile. Si eu am avut curiozitati si le-am lamurit.
3. Nea omul ala de la BS Motors, stia ce vorbeste, este proprietar de 4x4 (Toyota Hilux), si ii luase si nevesti-sii un SX4. Dar daca unii aveti inselatoarea senzatie ca v-ati luat SX4 ca sa aveti tractiune chiar si pe roata de rezerva, n-aveti decat. Eu nu am nici timp, nici bani de riscuri si deocamdata prefer sa ascult pe cei avizati. O zi buna.
Suzuki SX4, GS 1.6 4WD
Offline bogdanb
Re: Despre 4x4
« Răspuns #83 : 02.Iun.2009, 06:01:27 p.m. »
@cristian_ionescu: Dragule, nu inteleg de ce esti asa iritat; la urma-urmei discutia a pornit de la relatarea facuta de tine!
Revenind la tema, de fapt tu ai aflat cum functioneaza tractiunea integrala la SX4?
« Ultima Modificare: 02.Iun.2009, 06:04:18 p.m. de bogdanb »
Re: Despre 4x4
« Răspuns #84 : 02.Iun.2009, 06:07:14 p.m. »
pana va certati mai aruncati un ochi si pe alte pagini din forum...
Offline bogdanb
Re: Despre 4x4
« Răspuns #85 : 02.Iun.2009, 06:14:36 p.m. »
Promit ca e ultimul offtopic din acest topic  :D : Nu ne certam, doar ma intereseaza DE CE se strica masina cand mergi pe Permanent sau Auto asa cum relata cristian_ionescu, de preferat cu alte argumente decat "de-aia" sau "asa a zis Cutare".
Offline pentium3d
  • Mesaje postate: 193
Re: Despre 4x4
« Răspuns #86 : 02.Iun.2009, 06:20:08 p.m. »
Si cand mergi 2WD se strica...normal ca se strica si cand mergi 4*4, important e sa fie peste zeci de ani  :D
PS: si daca sta pe loc se strica  B-)
Offline anyd
  • Mesaje postate: 732
Re: Despre 4x4
« Răspuns #87 : 02.Iun.2009, 06:59:33 p.m. »
... in concluzie de ce se strica daca mergi 4x4 auto stie cineva?.... si atunci cum trebuie sa mergi numai cu tractiune fata?....
Offline xim
Re: Despre 4x4
« Răspuns #88 : 02.Iun.2009, 11:32:03 p.m. »
Legat de 4x4...
In modul auto...lampa din bord ar trebui sa fie tot timpul aprinsa ... sau doar cind se realizeaza efectiv transmiterea de cuplu pe rotile spate...ceva gen esp?
1,6 SX4 GS 4x4 black
1,4 Scross Passion awd, gray
Re: Despre 4x4
« Răspuns #89 : 02.Iun.2009, 11:34:31 p.m. »
permanent
