Autor Subiect: GV-Recall vehicles and VIN affected  (Citit de 2514 ori)
Offline coq
« : 19.Ian.2009, 04:43:56 p.m. »
Sunt articole vechi... poate unii le-au gasit poate altii nu.
Eu zic ca totusi este bine sa le afisam, in speta ii priveste pe cei care vor sa achizitioneze Grand Vitara motorizare diesel, second hand.
Suzuki Grand Vitara 1.9 Diesel: RISK OF FIRE
It has been identified that due to an improper design of the intercooler inlet hose, there is a possibility that the air/fuel mixture ratio
may be incorrect within the diesel particulate filter assembly.
This in the worst case may cause the diesel particulate filter to ignite. Recalled vehicles will be fitted with a modified intercooler hose.
Vehicle’s VIM affected:
                                  JSAJTD44V00102735 to JSAJTD44V00218932
It has been identified that the intercooler has been improperly designed. This may allow the intercooler to come apart in use,
causing an improper mixture ratio of air/fuel in the diesel particulate filter.
In the worst case, the particulate filter may ignite.
Recalled vehicles will be fitted with an engine intercooler attachment assembly.
                                   JSAJTA44V00100031 to JSAJTD44V00208913
Suzuki Grand Vitara 1.9 Diesel: WIRING HARNESS MAY CHAFE RESULTING IN POSSIBLE LOSS OF ENGINE POWER
It has been identified that, due to improper insulation of a branch of the engine wiring harness.
The possibility exists that the harness can chafe on the cam cover securing bolt, and sustain damage.
Should this occur, a possible sudden loss of engine power might ensue.
Subject vehicles will have the engine wiring harness inspected, and repaired as necessary, before being fitted with a protective cover.
                                 JSAJTD44V00103047 to JSAJTD44V00211187
Sursa
http://www.suzuki4u.co.uk/news/category/suzuki-grand-vitara/
« Ultima Modificare: 24.Ian.2009, 12:39:35 p.m. de coq »
