Autor Subiect: Probleme la pornire și nu numai  (Citit de 363416 ori)
Offline bogdanb
« Răspuns #1380 : 26.Iul.2010, 12:54:17 p.m. »
... cine intra in apa sa scoata Tuaregu' ...
E chestie si de sofer, nu doar de masina. Pe langa ca IMS-ul avea cauciucuri Mud (totusi, nu stiu daca asta il ajuta la ceva), soferul  a intrat incet in apa. In timp ce ala cu Tuaregul, pe ideea "io am masina de teren" a intrat in viteza si evident ca apa l-a franat, a inceput sa planeze, pierzand aderenta i-a murit motorul si tot asa din una in alta. Poate nici nu o fi cuplat 4x4 lock sau cum s-o chema  la VW....
SX4 4x4 1.6GS aka Suzie Q :)
« Răspuns #1381 : 26.Iul.2010, 01:09:14 p.m. »
Aici a tinut strict de sofer. "Bizonu'" a ignorat cea mai elementara regula la condusul prin apa - mersul incet.
Roger Crathorne, manager of the Land Rover Driving Experience, explains. "If there's one thing that will stop you, apart from underwater obstructions such as sunken trees, it is water being sucked into the engine. You must understand the geography of your vehicle, particularly where the engine's air intake is; which side of the car, at the front or the back and, crucially, how low it is. Some off-roaders have particularly low and vulnerable air intakes.
"You should always enter water really slowly (about 1-2mph), but if you then accelerate to about 3-4mph you can create a bow wave in front of the vehicle, which will create a depression in the engine bay and keep the air intake clear of water. This technique doesn't work with beam-axled 4x4s, as the water tends to hit the front axle beam and squirt straight into the engine bay."
Offline Razvan
  • Mesaje postate: 926
  • Thanked: 35 times
« Răspuns #1382 : 26.Iul.2010, 01:30:38 p.m. »
Uitati-va la faza anterioara celei cu Tuaregul sa vedeti cad de detasat si cu ce viteza a trecut Nissanul prin pasajul respectiv
Vitara Passion Hybrid 2WD
BMW G310GS
Mobil 0744.338.792
Offline edy70
Raspunde la numele de ZAMBI.
Offline whizzy
  • Mesaje postate: 2040
« Răspuns #1384 : 27.Iul.2010, 03:59:46 p.m. »
Offline Leutz
« Răspuns #1385 : 27.Iul.2010, 04:50:06 p.m. »
 :clap:  :clap:  :clap:  :clap:
Offline deconectat
  • Mesaje postate: 762
  • Membru cu logan
« Răspuns #1386 : 27.Iul.2010, 06:38:41 p.m. »
Offline bogdanb
« Răspuns #1387 : 27.Iul.2010, 10:28:45 p.m. »
Eu de multe ori m-am intrebat din ce gramada de excremente au iesit gandacii astia de gunoi care isi permit nesimtirea sa ne reduca la o simpla si banala "resursa"...fie ea si "umana"  X-(
Fiindca tot cretinii astia, daca de exemplu ai peste 30 de ani si doua licente, nu te angajeaza fiindca "esti supra-calificat" sau "de fapt postul nu necesita calificarile dvs" sau "pana acum chiar nu ati ocupat nici un post de conducere?"
Offline mxxa
  • Mesaje postate: 1459
« Răspuns #1388 : 28.Iul.2010, 08:41:26 a.m. »
un raspuns ar fi :
Offline edy70
« Răspuns #1389 : 29.Iul.2010, 12:07:54 p.m. »
