Autor Subiect: Cruise Control IGNIS, Swift, SX4, Splash, Grand VITARA  (Citit de 100670 ori)
Offline anakin28
  • Mesaje postate: 67
Re: Cruise Control IGNIS, Swift, SX4, Splash, Grand VITARA
« Răspuns #40 : 29.Ian.2009, 12:09:01 a.m. »
ceva detalii?
cate zile zici ca mai asteptam?
Pai Cristi ar trebui sa ne lumineze...daca el nu zice nimic...
SX4 1,9 DDIS - Sunlight Copper Pearl
« Răspuns #41 : 29.Ian.2009, 09:34:44 a.m. »
eu astept kitul de sx4 de data asta sper sa ajunga pana in 15 februarie
  • Mesaje postate: 1615
  • Thanked: 252 times
« Răspuns #42 : 30.Ian.2009, 11:34:34 a.m. »
il montezi tu??cit a costat??
« Răspuns #43 : 30.Ian.2009, 11:42:34 a.m. »
il montez eu... nu iti  mai sic cat a costat ca prostii mi-au trimis unul de kia sorento prima oara...
taxe postale...
o sa detaliez mai in colo daca merita.. adica daca merge
eu am testat e am scris mai demult.. o simulare a ceea ce cumpar.. si nu merge.
mai astept vesti de la cei de la service/.... altfel.. sorryyy pt banii pierduti
Offline csaba
  • Mesaje postate: 220
  • Suzuki Ignis 1.3 GC spring green metallic
« Răspuns #44 : 04.Feb.2009, 08:58:09 p.m. »
scuzati ca ma bag si eu dar as vrea sa va sugerez sa va uitati un pic aici http://masini.ro/forum/content-page/19254/Imbunatatiri-SX4/page/20/
« Răspuns #45 : 04.Feb.2009, 09:23:07 p.m. »
csaba bacsi,
Asa cum ai vazut si in link-ul pus de tine, baietii de la doverkft.hu mi-au raspuns destul de repede:
Thank you for your e-mail, about the cruise control in your Suzuki SX4. To fit a cruise in any car is not a simple work. By our experience many car electronic electritian gave up the installation, so this product is not recommended to install in a "do-it-yourself" way. (If you are an electronic expert, and you are resolute, you can try...)
If you want the cruise installed in your car (so the installation is not made by you) you have to come to our garage. The installation time is 4-5 hours, and the complete price (neccessary components + installation work + tax) is 110.000 HUF.
You can choose among 5 different command modules from. The most popular one is the CM35, which contains 2 pcs speed memory button, giving an extra function to this cruise control.
  • Thanked: 238 times
« Răspuns #46 : 04.Feb.2009, 10:57:22 p.m. »
Wow...cam scumput as spune. ~370E...Totusi e bine ca stim ca sigur se poate ;)
P.S. Nu am nici o veste...de la Suzuki :(
« Răspuns #47 : 05.Feb.2009, 09:55:54 p.m. »
de putut. E clar ca se poate. Un raspuns util ar fi: trebuie electronica in plus? Daca NU o sa pot sa o fac eu repede. Daca DA e mai complicat.
« Răspuns #48 : 11.Feb.2009, 09:47:32 a.m. »
Hello all,
A primit o oferta buna dar grea... pt 1oo de CC-uri. voi incerca sa mai negociez ceva. mi-e greu sa cred ca vom fi 1oo de doritori de CC. In ideea de a vedea cati ne adunam am facut o lista; cine isi doreste CC il rog sa se inscrie acolo.
Avantajul e ca merge si pe swift si pe splash cu butoanele pe volan originale... poate ajungem la 50 dar si 50 de doritori cred ca e greu e gasit
http://spreadsheets.google.com/ccc?key=pmWTcFmbssJ1JV2-bhfRscQ
mailul de la DANCAR:
Hello Lucian,
Here you find the installation manual for the Swift-SX4-Splash with OE command modules.
Normally we deliver the Comfort Cruise Kit without any command module and the command module separately. To this kit only the OE command module works. So we deliver 2 numbers.
CC50-0303 - Comfort Cruise Kit without command module
37460-79J00-ZCP - OE command for Suzuki Swift-SX4-Splash
The export price is € 236 ex. works and the minimum ordering quantity is 100 pieces. A smaller quantity will increase the price due to increased production cost. The delivery time is 6-8 weeks.
About our products:
Our product is the only cruise control on the market there are CAN BUS digital. We have the patent on digital CAN cruise controls.
Our product is a fully plug-in solution where you don’t cut any wires in the car, witch reduces the assembly time and risk of common assembly failures. Our product has an estimated mounting time of app. 70 minutes. No other product is this fast to mount.
« Ultima Modificare: 11.Feb.2009, 11:42:49 a.m. de miocrl »
« Răspuns #49 : 11.Feb.2009, 01:03:28 p.m. »
Eu m-am trecut pe lista. Mai exista doritori?
