Autor Subiect: Stiri pe scurt...  (Citit de 374401 ori)
Re: Stiri pe scurt...
« Răspuns #110 : 09.Iun.2009, 03:17:36 p.m. »
Two shots taken inside the plane before it crashed. Unbelievable! Photos taken inside the GOL B 737 aircraft that was involved in a mid air collision and crashed.....
A B737 had a mid air collision with the Embraer Legacy while cruising at 35,000 feet over South America . The Embraer Legacy, though seriously damaged with the  winglet ripped off, managed to make a landing at a nearby airstrip in the midst of the Amazon jungle. The crew and passengers of the Embraer Legacy had no idea what they had hit. The B737
however crashed, killing all crew and passengers on board.
The two photos attached were apparently taken by one of the passengers in the B737, just after the collision and before the aircraft crashed. The photos were retrieved from the camera's memory stick. You will never get to see photos like this. In the first photo, there is a gaping hole in the fuselage through which you can see the tailplane and vertical fin of the aircraft. In the second photo, one of the passengers is being sucked out of the gaping hole.
These photos were found in a digital Casio Z750, amidst the remains in Serra do Cachimbo. Although the camera was destroyed, the Memory Stick was recovered. Investigating the serial number of the camera, the owner was identified as Paulo G. Muller, an actor of a theatre for children known in the outskirts of Porto  Alegre . It can be imagined that he was standing during the impact with the Embraer Legacy and during the turbulence, he managed to take these photos, just seconds after the tail loss the aircraft plunged. So the camera was found near the cockpit. The structural stress probably ripped the engines away, diminishing the falling speed, protecting the electronic equipment but not unfortunately the victims. Paulo Muller leaves behind two daughters, Bruna and Beatriz.
Offline ..::Khaos::..
  • Mesaje postate: 5819
  • Thanked: 3 times
« Răspuns #111 : 09.Iun.2009, 03:34:42 p.m. »
Am primit si eu pozele alea pe mail... :-S
Offline deconectat
  • Mesaje postate: 762
  • Membru cu logan
« Răspuns #112 : 10.Iun.2009, 08:53:30 p.m. »
Lanseaza Dacia o noua masinuta? ;-) Dacia Rondo
Din pacate poza e un photoshop ordinar...dar ideea e buna, daca masina ar fi si ieftina...un concurent pentru smart sa zicem.
O idee si mai buna ar fi o masina mica si ieftina cu 4 locuri...un fel de matiz...
Offline bogdanb
« Răspuns #113 : 10.Iun.2009, 10:32:27 p.m. »
Ati observat si voi un paradox? ca marii producatori tot vorbesc de ecologie, de economie de resurse, de verde, ca sa facem masini mai mici mai economice, care "sa faca fata provocarilor din traficul urban"... cind colo, majoritatea fac masini din ce in ce mai mari si care mai rau ingreuneaza traficul.
Sigur, exista si exceptii gen Pejo 107 dar parca sunt cam putine....
SX4 4x4 1.6GS aka Suzie Q :)
Offline Leutz
« Răspuns #114 : 11.Iun.2009, 02:53:48 p.m. »
Artticol din evenimentul zilei : Drive-test Suzuki Swift 4x4
Chiar şi cu tracţiune pe ambele punţi, Swift 1.3 4x4 rămâne, prin excelenţă, o maşină de oraş
Dacă Subaru, tot o marcă japoneză, trimite cu gândul la sportivitate şi, bineînţeles, la 4x4, Suzuki are în subsidiar accesibilitatea. Nici una, nici cealaltă nu se bucură de notorietatea celor „trei mari” din Ţara Soarelui Răsare - Toyota, Honda, Nissan -, şi e foarte posibil ca Mazda să le întreacă de asemenea.
Comparaţia cu Subaru trebuie privită prin prisma faptului că întreaga gamă Suzuki comercializată la noi, cu o singură excepţie (Splash), dispune, oricât ar putea părea de surprinzător, de serviciile unor sisteme de tracţiune integrală.
Swiftul pe care l-am testat recent, model proiectat să supravieţuiască în jungla urbană, face parte din brigada 4x4 de la Suzuki. El are doi colegi mai mari, crossoverul SX4 şi SUV-ul compact Grand Vitara, dar şi unul mai mic, SUV-ul de buzunar Jimny - excelent adaptat pentru campaniile conduse la mare depărtare de ultimul petic de asfalt.
Concurenţă firavă
Swift 4x4 abia dacă are un concurent direct. În oferta Fiat pentru România, poate fi identificat micul Panda 4x4 (12.174 de euro), care se califică drept cel mai apropiat model ca dimensiuni (deşi cu peste zece centimetri mai scurt) şi „tehnică de luptă”.
Chiar judecând doar prin prisma amprentei la sol - al doilea cel mai mic Suzuki (depăşit la acest capitol de mai noul Alto, necomercializat încă la noi) se încadrează undeva la graniţa segmentelor A şi B - se pot identifica doar o mână de adversari. Nissan are Micra, Toyota defilează cu Yaris, Citroën propune perechea C2 (autoturism disponibil exclusiv cu două uşi) - C3, iar Subaru oferă Justy, un model care face notă distinctă cu restul gamei, punând puterea pe caldarâm doar prin intermediul roţilor anterioare.
În mod paradoxal, Swift îşi găseşte un rival şi în propria ogradă - modelul Splash, cel care, spuneam, nu posedă şi o versiune cu tracţiune 4x4.
 Foto: Suzuki - vezi link-ul catre articol
ECONOMIE. Bord curat, dar realizat cu materiale plastice dure
Echilibru contra zvâc
Transmisia integrală nu transformă Swiftul dintr-un model cu veleităţi preponderent urbane (perfect capabil să susţină călătorii lungi) într-unul adaptat incursiunilor în off-road. Garda la sol modestă şi sistemul 4x4 simplist sunt tot atâtea frâne în calea unui progres constructiv pe teren accidentat.
Astfel „înarmată”, maşinuţa gestionează cu folos ieşirile la iarbă verde şi, poate cel mai important, deplasările pe drumuri asfaltate cu aderenţă scăzută (ploaie) sau precară (zăpadă).
Swift 4x4 are un motor pe benzină, cu patru cilindri, de 1.3 litri, care dezvoltă 92 de cai-putere la aproape 6.000 rpm. Dacă versiunea dotată similar, dar cu tracţiune faţă, este deosebit de inimoasă şi distractivă, aceasta pierde din zvâc, greutatea suplimentară (165 de kilograme, echivalentul a două persoane de talie medie) penalizând dinamica maşinii.
Sprintul de la zero la 100 km/h este apăsat de aproape două secunde adiţionale, motorul trebuind ţinut la regimuri înalte de turaţie pentru demaraje satisfăcătoare.
Sistemul 4x4 nu este ieftin. La un nivel de echipare similar, acesta impune o cheltuială mai mare cu 1.900 de euro. Chiar şi aşa, cei care apreciază siguranţa suplimentară garantată de prezenţa sa trebuie să achite doar 12.550 de euro inclusiv TVA, preţ de listă.
Pe lângă sistemul de tracţiune integrală, Swift 4x4 oferă, între altele, ABS şi EBD, airbaguri faţă, aer condiţionat, geamuri şi oglinzi electrice, radio-CD (MP3), servodirecţie şi închidere centralizată.
« Răspuns #115 : 11.Iun.2009, 04:54:05 p.m. »
Constatarea amiabila
De la 1 iulie 2009, accidentele rutiere survenite pe teritoriul Romaniei, in urma carora au rezultat numai pagube materiale si in care au fost implicate doua vehicule, vor putea fi solutionate fara ca documentele de constatare sa fie intocmite de catre Politie, cu conditia ca Formularul de constatare amiabila sa fie completat si semnat de catre ambii soferi implicati in accident.
... Constatarea amiabila
« Răspuns #116 : 11.Iun.2009, 08:07:20 p.m. »
Postati repede, ca vine vijelia si nu se stie ce mai ramane din structurile de comunicatii... :D
Offline bogdanb
« Răspuns #117 : 12.Iun.2009, 07:43:31 p.m. »
O stire pe care am aflat-o azi, desi nu e chiar noua: acum 3 zile un nemernic, nenorocit, iresponsabil, nu stiu cum sa-i mai spun, a omorat cu masina ursuletul din poza atasata  =((
Cat de nemernic trebuie sa fie cineva care accidenteaza mortal un animal nevinovat pe un drum unde se merge cu 30km/h? Astia ar trebui sa infunde puscaria pentru omor deosebit de grav (ursul brun fiind specie ocrotita) si apoi pentru ca e un potential pericol la siguranta cetateanului: maine-poimaine acelasi nenorocit ar putea sa dea cu masina peste copiii nostri, pe aleea de langa bloc, cu aceeasi seninatate ... X-(
« Răspuns #118 : 12.Iun.2009, 10:41:12 p.m. »
Un mass primit acum citeva minute pe YM:
ecomagazinro (12.06.2009 19:51:34): Sambata, incepând cu ora 10.00, sunteti rugati sa participati la un miting de protest la adresa actiunii de “distrugere” a 20.107 metri patrati (2 hectare) din Parcul Tineretului. http://www.ecomagazin.ro/ong-urile-organizeaza-o-actiune-de-protest-pentru-salvarea-parcului-tineretului/ Suprafata de teren a fost trecuta in proprietatea femeii de afaceri Marioara Micsunescu printr-un schimb de terenuri cu Primaria Capitalei. Ce pot sa zic mai mult... e weekend, ne vedem in parc, sa sa facem poze si sa aratam nepotilor cum era candva Bucurestiul... nu mai fiti nepasatori! Daca nu poti veni trimite pe cineva in locul tau!
Offline Racky
  • Mesaje postate: 499
  • Romanian Road Runner - Membru "adoptat"
« Răspuns #119 : 15.Iun.2009, 12:49:29 p.m. »
Da nimeni nu se uita la serialul LOST  :-/ Vedeti oleaca:
« Ultima Modificare: 15.Iun.2009, 02:48:22 p.m. de cristyyy2003 »
 Meniu pescaresc : dimineata CRAP de foame, la amiaza STIU CA n-am ce manca, iar seara SOMN pe stomacul gol.
