Autor Subiect: Coduri piese Swift<2005  (Citit de 38400 ori)
Offline dexter
  • Mesaje postate: 158
« : 24.Apr.2010, 07:48:45 p.m. »
Salutare.Observand ca exista si cateva Swifturi model IV in club (excluzandu-l pe al meu :D) m-am gandit sa postez niste coduri de piese,atat cat am cercetat eu pentru Aburica mea :x.Daca mai stiti si voi alte coduri,verificate, nu va sfiiti sa completati lista :D,oricum ea ramane deschisa.
16510-61A01     filtru ulei OEM TOKYO ROKI
16510-61A20   filtru ulei OEM KNECHT
w67/2              filtru ulei  AM   MANN
OL218-J            filtru ulei AM   TECNECO
13780-82400   filtru aer OEM
YUS-012           filtru aer  AM YUIL FILTERS
20-08-809   filtru aer  AM ASHIKA
10725      filtru aer  AM TECNECO
J1328009      filtru aer  AM JAKOPARTS
J2008003      Kit ambreiaj JAKOPARTS
826279           Kit ambreiaj VALEO
SZK2006      Kit ambreiaj EXEDY
3000 520 002   Kit ambreiaj SACHS
0002335607   Bujie 4 poli BERU
0 241 235 697   Bujie Super, 3 poli,    BOSCH
BPR6ES      Bujie NGK
EON1      Bujie CHAMPION
09.5857.14   Disc frana BREMBO
0 986 478 540   Disc frana BOSCH
561599J           Disc frana   JURID
60-08-805   Disc frana   ASHIKA
J3318000      Disc franaJAKOPARTS
24.0117-0103.1Disc franaATE
12-0846      Placute frana ETF
FDB648      Placute frana FERODO
50-01-135   Placute frana   ASHIKA
13.0460-5921.2 Placute frana   ATE
21344 160 0 5     Placute frana   TEXTAR
30-08-890   Filtru combustibil ASHIKA   motor g13 bb
30-08-810   Filtru combustibil ASHIKA   motor g13 a,g13 ba,g13 b
804016      Rulment presiune VALEO
BRG438      Rulment presiune EXEDY
287-101      Toba esapament Mijloc+Spate BOSAL
52.8003      Toba esapament Mijloc+Spate ASSO   toate tobele pt. Hatchback
4001           Toba esapament Mijloc+Spate UNIX
48830-50G10      Bieleta de directie  Cu servo, OEM SUZUKI
 G2-119               Bieleta de directie fara servo,OPTIMAL
 103-08-804        Bieleta de directie fara servo, ASHIKA
 18.6106             Cablu ambreiaj  568/387mm COFLE
 ZU01103            Cablu ambreiaj  555/388mm  TECNOFLEX
 J2308011           Cablu ambreiaj   JAKOPARTS
« Ultima Modificare: 25.Apr.2010, 07:49:05 p.m. de dexter »
  • Thanked: 238 times
Re: Coduri piese Swift<2005
« Răspuns #1 : 24.Apr.2010, 08:56:29 p.m. »
Buna idee!  :good:
Ar fi bine ca ele sa fie centralizate in prima postare a acestul topic. Ce zice domnul moderator?  :-?
  • Thanked: 7 times
« Răspuns #2 : 24.Apr.2010, 09:10:23 p.m. »
Da,se face,nu e problema.
Intre timp topicu l-am facut sticky pt ca e f folositor.
Bravo Dexter!
Offline dexter
« Răspuns #3 : 25.Apr.2010, 10:11:25 a.m. »
Ma bucur sa vad deja 43 de vizite ale acestui topic,mai ales ca am vazut intr-un sondaj,ca sunt vreo 22 de posesori de Swift vechi pe forum :good:.
Offline HyperL
  • Mesaje postate: 46
« Răspuns #4 : 27.Apr.2010, 06:02:12 p.m. »
Foarte bune informatiile, multumesc dexter.
Am si eu ceva de adaugat, si anume atentie la achizitionarea filtrului de combustibil, are niste cleme speciale metalice cel OEM, altul nu am gasit sa se potriveasca. Asta am observat la ultima revizie cand am cumparat filtrul cautand dupa seria caroseriei si am luat mare teapa  X-(.
Suzuki Swift 1.3 GLX @63kW G13B
Model 2001 (achizitionat de nou in 2003)
Offline dexter
« Răspuns #5 : 27.Apr.2010, 07:38:49 p.m. »
Multumesc pt atentionare HyperL :).Eu am de la celalalt Swift al meu,filtrul de benzina Bosch,insa nu are nicio piesa metalica,in afara de suruburile de prindere. Asa e si la Swiftul din 2003.Singurul filtru care seamana cu asta este Ashika din primul post. Iar cu cautarea dupa seria caroseriei... :baston:,nu e relevanta de multe ori.Nu am prea vazut motorul G13BB in programele de piese auto,decat la Subaru Justy 2001-2003,el fiind un swift 4, 4x4, rebranduit,la Suzuki Baleno,si la Wagon R+,insa cu 76CP si ceva diferente mecanice.Sambata am luat de la Unix filtru de ulei Tecneco OL218-J,pt Justy 2003,motor G13BB,altfel "nu avem",pt ca  vanzatorii(cu mici exceptii) nu se obosesc sa se informeze un pic :(.
Offline RedRiver
  • Mesaje postate: 3
« Răspuns #6 : 05.Oct.2010, 09:23:55 p.m. »
Imi puteti spune daca exista coduri pentru elementele de caroserie?
« Răspuns #7 : 05.Oct.2010, 10:17:30 p.m. »
Pai cred ca-s multe elemente de caroserie. Cred ca ar fi bine sa le dai un indiciu baietilor ca sa te poata ajuta.
Offline dexter
« Răspuns #8 : 11.Oct.2010, 10:34:19 p.m. »
Salut. Uite aici toate codurile,inclusiv caroserie:http://www.venite.hu/suzuki/thumb/swift4.htm.Dai click pe pozle cu ce te intereseaza.De altfel,cu un mic search :inteligent:,gaseai chiar mai multe  site-uri mentioate pe forum.Daca ai swift 5 inlocuiesti cifra din link cu 5 si gata. Bafta. :)
Offline prikoke
  • Mesaje postate: 17
« Răspuns #9 : 08.Feb.2012, 02:38:50 p.m. »
ATENTIE!!
Acum 1-2 sapt, pe frigul cel mai aspru, m-a lasat cablu de ambreiaj. Las masina, sare un pireten care nu prea avea ce face mati sa imi ia un cablu ( dupa cei-am dat model, an, putere, .... tot ce trebuia) si seara ne punem sa montam. Dam jos vechitura rupta, apoi cand sa puntem noul cablu( made in italy) observam ca e PREA SCURT. Am tras de el si l-am lungit destul, apasa pe o conducta de frana, dar m-a tinut doua zile pana am luat altul  corespunzator (made in JPN). DECI atentie ca exista 3 lungimi de cablu pt swift <2005. Sfatul meu e sa luati cel mai lung ( 64cm, nu 57cm), pt 20ron scapati de inca o demontare foarte placuta.
