Salut si bine-ai venit!
Ti-am comasat postarile intr-una singura.
Raspuns la intrebare: nu stiu unde este "buzzerul". Ar trebui sa fie in spatele unor orificii prin care sa strabata sunetul, ca la orice difuzor.
De obicei problemele de acest fel au drept cauza ori emitatorul, ori receptorul, ori amadoua. Le-ai verificat pe ambele?
Ti-o spune unul care a epuizat o baterie uitand o noapte pozitiile aprinse. Dar era batrana si oricum murea...
Piuitorul meu face zgomot mare. Dar uneori sunt grabit sau anxios si nu-l aud. Si mi-am format un obicei sa nu cobor rapid din masina.
Update:
Am cautat intre timp in manualul de service si iata ce am gasit:
"BCM General Description
S5RW0CA201001
The Body electrical Control Module (BCM) is incorporated in the junction block assembly. Do not attempt removal of BCM from junction block assembly as it may cause contact failure.
The BCM incorporates relays and controllers which are used for the following systems and controls them.
• Power door lock (if equipped)
• Keyless entry (if equipped)
• Door lock function of keyless start system (if
equipped)
• Rear wiper
• Combination meter
• Interior light
• Warning buzzer
• Rear end door window defogger and door mirror
heater (if equipped)
• Rear end door opener (if equipped)
• Theft deterrent light
Also, the BCM has a function to cause the interior light and open door warning lamp in the combination meter to turn off when any door is left open for longer than 15 minutes to reduce wasteful battery consumption.
In addition, it is possible to check operation of actuator which is controlled by BCM by using the output test function of SUZUKI scan tool to operate actuator
simulatively.
When driver’s seat belt is unfastened (under the following conditions), seat belt reminder light and warning buzzer inform that the driver’s seat belt is unfastened. Seat belt reminder light located in combination meter and warning buzzer located inside BCM operates as follows:"
Deci, buzzerul este in BCM, iar BCM-ul este sub volan, dar nu-i bine sa umbli la el.
